wiping a flash drive - help !!
23 Jan 2007
Glasgow
wasnt sure whether this should go in the HD or memory section so plumped for general..
anyway..
ive got a Sandisk 4gb flash drive that has a small portion of its capacity used by U3 software that came pre-installed on it. Ive tried formating the drive to erase this rubbish program but it alwas re-appears when the drive is plugged back into the pc. Is there anyway to chop this useless program off the drive for good or am i stuck with it?
cheers
Try using some of the partitioning tools on Hirens boot CD to see if there is a hidden partition you can remove.
