Wiping a laptop
25 Sep 2007
Hertfordshire
Hey all
I have a laptop which was a works laptop but now my own, unfortunately it has admin rights and a virus so pretty much unable to do anything on it. Is there any way I can re install windows and wipe everything from it?
Cheaper the better aswell.
Cheers
Matt
Yeh, you use the recovery disks that came with it. If you don't have them then turn the laptop over. What version of Windows did it come with? Look for the Microsoft sticker if it come with Windows on it.
Or you could use a linux, google OS which is free.
It says it has windows vista buisness on the back of the laptop but when it boots up te login screen is windows xp professional.
