Wiping Hard Drives
For the time it takes to disconnect the drive(s) vs drowning in a pool of your own screams when you realised you've made a mistake, I'd say it's definitely worth it.
Personally i use Shred to fill the drive with 0's
Its much quicker than any drive wipers and will defeat any off the shelf data recovery software which to be fair is all you need unless you have some pretty dodgy content!
Yup... AFAIK it's simply not possible to recover any sort of useful data from a drive which has been completely zero-filled, there are certainly no documented cases of it ever having been achieved.
The time-consuming multi-pass-with-random-data options are really just for the terminally paranoid. :)
Realistically only one pass is required if you are using a random erase method. If you have truecrupt installed already you could just use that - use volume wizard to encrypt the hard drive (encrypt and format, not in place) that effectively fills the drive with random data.
CCleaner has a Drive Wiper in its Tools section.
I only noticed it the other day when I needed to wipe a drive but as ccleaner is pretty popular it might save you having to install something else.
I've used this. Quite good and you can select security levels to wipe too.
+1 for ccleaner
