Wire gauge for fans?
12 Apr 2016
Hi all,
I need some help with the red and black wire. I want to know what AWG size is for the red and black wire that most computer use?
I am thinking it is about 18 AWG but I am not too sure. The length of 2 pin wire I think is about 2mm.
The reason I am asking this is because I am looking for the PVC transparent wire size with the same size as the red and black wire that most computer use. I want to get the correct PVC transparent wire size because I want to make it more easy for me to attaching the wire on the side of the fans after when I have finish solder on the blue leds. I am going to solder the blue leds on the top of the fan to the transparent wire then solder the wire on the fan motor for my fans.
I've bought 22AWG transparent wire, but I have difficult to attached them on the fans as it is little bit too big so I need a little bit smaller size for the wire :)
