Wired access point with built in switch?
23 Mar 2005
I am trying to set up a garden room and have run into an odd problem. We have wired in a Cat 6 cable to the room, and are looking to plug it into an access point to provide wifi. I also want to have a switch, so we can wire in the TV and possibly another item or 2. Clearly I need an access point, and a switch, and I assumed there would be plenty of cheap ones (TP Link price point) on the market... but I can't find any.
If all else fails, I'll simply run: cable - switch - Access Point / TV etc.
I am not interested in using a router in AP mode (been there - done that - never had success...)
I am not interested in a range extender (we have the cable in place).
I don't want multiple wireless networks - it needs to be seemless for the user.
Help??
It's not at the TP-Link price point but the Ubiquiti UAP-IW-HD is an option. I've got one in my Study and it's does the job just fine.
It'll be cheaper to buy a seperate switch and AP but depending what AP's you're currently using it may be worth paying the extra for the UAP-IW-HD.
Several AP’s have a pass through port, or just use separate devices, the cost to combine them is usually disproportionately higher than individual pieces of equipment.
You don't need a router in access mode, you just need a router with Wifi turned on, then you just ignore the WAN port and use only the LAN ports, its what I do in my loft and spare bedroom. Also meant it cost me zero as I could reuse old kit.
Did look at some of the newer solutions - simply too expensive for what we are trying to achieve.
This was my take too. There are cheap options, with just a single pass through port - but one is not enough, and they all seem to be running 10/100 - I guess 1998 was a good year for stockpiling IT equipment :cry:
As I said, been there, done that - never had what I would term success (ie. set it up and forget about it) - glad it worked for you, but I (and many others online) have never been so lucky.
Bottom line is I will pick up a £10 switch, and a cheap access point to plug into it - job done - just surprised this isn't a thing, that's all. I guess the margins on mesh networks are more attractive ;)
Moot point, but is your TV capable of gigabit at a port level? Unless it’s recent/high end, the answer is probably not, much less that anything it does will actually use/benefit from that level of bandwidth other than direct playing a 4K REMUX. Also all the Unifi AP’s I have ever used have gigabit passthrough and are generally within a few quid +/- of TPLink, just remember everything is running through that single cable, so it may or may not be a bottleneck at some point. As to why the products don’t exist and aren’t cheap, would you devote costly R&D into making an expensive version of two inexpensive products combined when home users have little or no appetite for a multi port AP passthrough and SMB or greater understand the limitation in deployments anyway as passthrough is not going to have PoE, so is useless for further AP’s/VoIP/CCTV use? I mean you could design and 3D print a combined AP and switch if you want and have access to a 3D printer, but otherwise it’s not happening within budget.
