Hopefully a really simple one - but I can't spot the problem.
Trying to move large files between my main machine and the server. I am running a wireless network via an ASUS router which works perfectly. Too slow for large files as the main machine is on a wireless G card
I use a TP-Link TL-SG100SD gigabit switch (unmanaged) which I use to connect the machines only when I need to transfer. I disable the wireless (so it doesn't cheat) I have set both machines up on the same subnet (255.255.255.0) in the standard IP range (192.168.0.2 and 192.168.0.3 with the default IP gateway set to the standard 192.168.0.1) - Windows 8.1 machine is in WORKGROUP.
Sometimes it works, sometimes it doesn't
When it works the ping is about 0 and the transfer rate is about right for the kit at about 40Mb/s. But the last few times I have not been able to get the machines to see each other.
WHS v2 and Windows 8.1 - main machine as per thescreenshot link below (why won't the image show?)
When it works the ping is about 0 and the transfer rate is about right for the kit at about 40Mb/s. But the last few times I have not been able to get the machines to see each other.WHS v2 and Windows 8.1 - main machine as per the
