Wired for sound - help needed.
2 Jan 2007
I need some help getting my front panel headphone jack working with my sound card - it's driving me nuts! Here's the info:
Case = Antec Fusion
Mobo = Asrock 945G-DVI
Sound card = X-fi music oem
If I enable the onboard audio and install the drivers for it, everything works fine - I can plug my headphones into the jack on the front panel of the case and they work. However, this means I get lower quality sound, and I have to plug my speakers into the onboard audio ports.
If I set the onboard audio to Auto or Disabled and install the drivers for my sound card, I get higher quality audio and can plug my speakers into the sound card audio ports. But I get nothing when I plug my headphones into the front panel!
Is there anybody out there with the same case that can help me out?
the front panel audio ports will be plugged into the mobo, you need to find these and see if you can connect them to the sound card.
