Wired internet works, but not wireless
12 Dec 2010
It's always been fine but now all wifi on the phones in the house and sisters laptop have stopped working. As far as i know nothing has changed so have no idea what's caused it.
Thanks in advance for any advice.
It'll run on Android phones if you have one.
Did all the wireless devices stop working at the same time?
Do they still claim to be connected, or are they refusing to connect?
Are the wireless devices picking up valid IP addresses (also gateway addresses and DNS servers)? IPCONFIG /ALL at the command prompt will show this.
The device may not support the latest encryption/security on the router.
That is all I can say, if you've tried the laptop and it says it has connection. There must be a slight issue with the device and router compatibility.
Edit: If you get chance, try updating drivers and firmwares both on the laptop and the router/wireless network.
Lastly, search Google for any relevant bug/problem information. Usually with issues such as your's; it is caused by a bug/problem to do with a firmware/driver in need of an update.
Just throwing it in there but the OP mentions that none of the phones are working either over wireless.
Tried it all to no avail, family having a go at me to fix it and i've got no idea.
It doesn't say that it has connection, it won't connect but the signal is strong. Really strange.
Okay, that's strange. All the other computers in the house on wireless started working again. My sister mucked about too much and messed up her password, i gave her the proper one and it's working now.
Cheers for the help anyway guys. Much appreciated.
