I've recently moved house. My Cable modem/switch/access point is on the ground floor, in the living room, and my office is on the first floor. I have a server that I want to connect to the LAN, but I want it to be in the office.
There is an existing run of CATV cable that goes from the living room to the office.
Because the new house is a rental, I cannot make physical modifications to the property.
The way I see it, I have limited options:
#1 is slow, but reliable; I've checked reviews and it seems that even the 500Mbps versions with 10/100/1000 Ethernet top out around 160Mbps.
#2 should be be fast and reliable, but the only vendor is StarTech and they want £260 for a set of transceivers.
#3 is the ideal, but part of the run of CATV cable goes under carpet, and I don't know whether is was laid before or after the carpet was installed. It's cut into the carpet at both ends of the run, so I don't know if I would be able to fish a cable through or not. The rest of the run is held with cable staples, so it should be reasonably easy to replace if I cut the end off the CATV cable.
#4 is easy and, as my AP supports 5G 802.11N, it should be fast, but not necessarily reliable.
Is there an option I've missed? Is there a better version of powerline networking that I should be aware of? Is £260 for the Ethernet over CATV box justified?
- Use powerline networking
- Buy a coax Ethernet extender
- Try to replace the CATV cable with an ethernet cable
- Add a wifi card to the server
