I've dropped in some 6 core alarm cable to power a wired Ring doorbell, no chime I'll be using various Dot's around the house so direct run to the transformer and back to the CU. Originally I planned on putting the transformer in a Din box just inside the garage and about 2.5-3M from the actually doorbell and then larger cable back to the CU, the 6 core is still on the reel uncut and the new front door arrives next week before the plasterer makes good.
I would like to run the cable directly back to the CU and skip the separate Din box and have the transformer fitted to the main CU, but cant find an accurate calculation for the length of the run, cable is 24AWG I believe and the run is no longer than 10M, I've got an opportunity to change the cable size before the doors fitted but also don't want to go too big as the connections on the doorbell are tiny.
Anyone able to help?
