Wired to Wireless Router
15 Jan 2006
Scotland
I have set up and configured WG834G router with an ethernet cable to a single computer and can successfully connect to the internet.
How do I now change it to a wireless connection by using a WG111 USB adaptor on the same computer? I am using Windows XP SP2
Only a single computer is required and all of the threads appear to be for connecting multiple computers.
Any help would be appreciated.
Axel
Well i've never tryed doing this without the router being connected to a network card , im taking a shot..
First off while your connected to your main computer via ethernet id setup your wireless network so that its enabled (write down what's needed) wep password etc. Detatch the ethernet cable plug in the usb adaptor, let windows wireless pick up the signal etc , enter password blah blah then done! , i think then you can acess the router from the main computer as you could before ... but id rather use a wire to the main pc any day :P more secure , wep etc isnt everything.
