- Virgin media 10mb split between 4 students
- Router in downstairs bedroom
- PC will be upstairs
- Currently 100% signal upstairs on laptop
- Room mate is going to use 30m wired cable
I am moving in the next few days and want some advice on which components to buy to get optimum performance for my ping in gaming.
My roomy is going to use a 30m ethernet cable and I am next to his room upstairs so it makes sense to use a cable as his will be throughout the house anyway so if I get wireless or flat cable to be tidy it seems pointless and more expensive. Is cat5 satisfactory for a 20m cable on 10mb?
The cheapest option seems to be wired 20m cat5 flat cable for 20m CAT-5e RJ45 (RJFLAT-20) Beige FLAT for just under £8 delivered seems like a deal breaker to me? Advice please! thnx
