WireGuard announces NT kernel module
18 Aug 2007
Liverpool
For those who use VPNs:
The WireGuard project has announced the experimental release of a Windows NT kernel module for the VPN protocol. For now, it's hidden behind a registry tweak (WireGuard version 0.4 and above), which can be added with, in a command prompt:
Code:
reg add HKLM\Software\WireGuard /v ExperimentalKernelDriver /t REG_DWORD /d 1 /f
Restart WireGuard and you'll be using the in-kernel implementation rather than the userspace-go version. Initial results suggest full gigabit with 0% CPU usage over Ethernet, and >600Mbps with minimal latency over WiFi 6. This is a significant jump over the previous userspace implementation, and puts Windows networking performance on par with that of Linux, OpenBSD etc. Congrats to Jason and the team. :)
As the 'experimental' tag denotes, this is early doors. I've found absolutely no issues under heavy testing and throughput has been amazing (Windows 10 Enterprise x64/Windows 10 Pro for Workstations, Intel I211 NIC) but there have been a few reports on Reddit of blue/green screens with some Win10 and Win11 installs. The posters didn't seem very technical though, so a pinch of salt required perhaps (underlying issues, incorrect application of the reg key etc).
Edit: Kernel driver version 0.2 released (part of the WireGuard app update) to address a crash in Windows 10 and 11.
