Wireless 360 pad for PC
5 Apr 2008
Thinking of getting one of these but having never used a 360 controller before i've got a couple of questions:
Can you use multiple pads at the same time with the one receiver? e.g. the pad that comes with it plus more pads from a 360.
Does it come with a rechargable battery pack or does it take AAs? If it's rechargeable I assume it comes with some type of USB charger cable?
The controller in question: http://www.overclockers.co.uk/showproduct.php?prodid=GC-001-MS
Yeah the receiver is pretty good. I'd just buy some decent rechargable AAs, my Play and Charge kit is useless, losing it's capacity very quickly and now holds no charge at all >.<.
yeah, i've got it too and it works fine. i have the 360 recharger thingy which is fine for me but you could always buy those usb rechargeable batteries
yes you do, there great lol i use mine in a few games when i put pc on the 32" hd tv and wana chillax lol
if you have an xbox 360 you can always buy the receiver on ebay and use the one you have for that..
