Hi
I want to update the lan card on my laptio, it's easily doable as it can be reached in the gap after you remove the hard drive cover.
It's a bg standard bgn card. I want to benefit from the newly installed wireless AC router in my home.
The wireless AC half height cards cost around £25 on ebay, but there are several wireless A (a only) cards for a bit less. Are they the same stuff or will wireless a be slower than ac?
