Wireless Access Point help.
26 Feb 2004
Hampshire, England.
Hey guys,
I need to increase the range of a wireless network I'm looking at; I've got a wireless router and a wireless access point; what kind of configuration can I use to extend the range of the wireless signal to allow my user to access the network through the access point? Atm, users can see the original network but the signal is just too weak to reliably connect too…
I've got a netgear ap and there are loads of options but I'm a bit lost :(
Thanks.
Greetings,
Have a look here :
Netgear AP Help
Seems like a good bit of work is needed.
Using Ap`s is not some thing i have done much with to be honest but should be ok with this site.
Ps: on the guide replace the WG602v2 with your main router.
