Wireless across an old farm
16 Mar 2012
So, we've just moved into a new place which is an old farm. There is so much work to do, but to start with I need my wireless at as many points as possible across the site....I can't deal with the EDGE connection on my phone!
So, what kind of solution do you think I should be looking at for this scenario:
-Broadband/ADSL connection to the office (smallish out building)
-Main farm thatch cottage 50-60metres away across an open space
-Two barns another 25m behind the cottage (corrugated iron)
Any suggestions are welcome as my old router only makes it about 3/4 of the way to the cottage at the moment.
Thank you
String a few lentpgths of cat 6 to the other buildings and add a wireless point in each for now
Then bury your cables when you have time
Ubiquiti Nanostation M 5Ghz will do a good job as a point-to-point link across 60m of open ground. They are dirt cheap as well.
