wireless adapter keeps turning on and off
25 Jun 2009
Weston-super-Mare
hi there.
im experiencing issues with my ZyDAS ZD1211B network adapter (prity sure i got it from ocuk a while back), and was wondering if anyone had any ideas for resolving the issue?
ive installed the drivers, i connect the device, found new hardware pops up, recognises it as the right thing, the little wireless thingy pops up n starts to find networks, then it turns itself off for a split second, then connects again, and gets caught in a loop and eventually gives up :S. it turns off after about 4 seconds n loops for between 1 and 5ish times, then just turns off. taking it out again and putting it back in starts a new series of loops
ive tryed using differnt usb ports, tryed reinstalling the drivers. ive been using the adapter for a couple of years and have experienced no problems (apart from it having low range cos its cheap), but after this format ive not been able to get it going again, and i need my css fix lol.
thanks in advance from the new boy
