Wireless Adapter (USB/PCI) for Windows 7
18 Sep 2003
Radlett
Hi chaps,
Can you recommend a wifi adapter for an 802.11G wifi network that will work with Windows 7 x64 (preferably with as little hassle as possible)? It's for a desktop computer. Apologies if this has been covered before - you can't search for "Windows 7" as 7 is below the three-letter minimum :o
Thanks
I've got the Edimax EW-7728IN (PCI card) on my Windows 7 x64 install. Worked out of the box and it automagically installed drivers once it detected new hardware, so i never bothered doing it manually since it works fine as it is.
