- 17 Dec 2007
- Edinburgh
hi guys
we used to use 2 BT Voyager 1055 USB wireless adapter but recently one of them failed which now means we are a wireless adapter down
it was my adapter that failed and i'm currently using the one out of the other machine which is only causing arguements, lol, so i'm looking at getting another adapter
With the BT Voyager 1055 i found that it was rather unstable, needing to be unplugged and replugged every so often as it just lost the connection - this is hopeless for trying to leave downloads running overnight so i have been looking at PCI adapters as i'd hope they are more stable, but maybe the adapter was fine and it the USB ports in my Evga 680i that are unstable.
so, would it be worth trying another USB wireless adapter or just get a PCI one and what ones would you recommend.
thanks
thanks
