Hey,
Looking to swap out my current PCI wireless card for a usb adapter.
Was considering N600 Wireless Dual Band USB or the TP like high gain one OC have but not sure if i should stick to PCI/PCIe cards. Router is literally 3m from my pc but i cant use cables. I still seem to get 70-100ms in BF3 and random bad connections.
Will I see any major differences using usb? Only concerned about gaming latency/stability, nout else. Read on another thread about speaking to Sky regarding interweaving, so will check that out to.
Having a usb adapter will let me stick my xonar dg into the PCI slot to so thats an added bonus. The two adapters ive mentioned above will cost roughly including postage.N600 Wireless Dual Band USB Adapter
Any recommendations would be welcomed.
