Hi,
I originally posted this issue in the Windows forum but it's developed somewhat and is now almost certainly related to my network card.
The symptoms: at random I will enter a spike period. A soon as this spike period begins my wireless adaptor drops out also. One of my cores spikes to 100% use, this kills my computer and it completely hangs for about 2 seconds. It's then a matter of a couple of seconds until the next spike, and so on. This will continue until I reboot - or more recently I discovered if I disable the wireless adaptor they cease!
Using processor explorer I was able to trace the cause of the spikes. This turned out to be Deferred Procedure Calls. I don't claim to understand what they are, but I used RATTV3 to monitor my DFC to try and determine what was causing the problem.
Here's what I believe to be the key part of the log file:
The times in bold stuck me as abnormally high in comparison to the others. NDIS.sys is network related is it not?
My network adaptor is a F5D7000UK. Since my PC upgrade I have experienced problems with connection drops outs too - requiring a connection repair until I could re-connect. I have tried different drivers including RaLink chipset generic drivers. This is a fresh OS install. On my previous system the card worked faultlessly. What has changed since the last time I used is new hardware in my system. Could this be some sort of device conflict? Could it be a problem with NDIS.sys? Could I have damaged my card?
I'm unsure as to what steps to take next really... and whether what I've assumed so far is correct. Therefore if anyone can shed some light on this I'd greatly appreciate it. Cheers.
Code:
Cumulative Histogram for: NDIS.sys (NDIS.sys)
#, Range, Label, ISR Count, DPC Count, DPCTmr Count
0, 0.00us to 0.99us, <1.00us, 0, 96371, 46773
1, 1.00us to 1.99us, <2.00us, 18641, 62289, 73064
2, 2.00us to 2.99us, <3.00us, 4820051, 370870, 69360
3, 3.00us to 3.99us, <4.00us, 1536593, 782946, 40438
4, 4.00us to 4.99us, <5.00us, 813596, 4065035, 10038
5, 5.00us to 5.99us, <6.00us, 70070, 411226, 4135
6, 6.00us to 6.99us, <7.00us, 12769, 291228, 1025
7, 7.00us to 7.99us, <8.00us, 4049, 319564, 1397
8, 8.00us to 8.99us, <9.00us, 2164, 149682, 1633
9, 9.00us to 9.99us, <10.00us, 809, 65472, 2653
10, 10.00us to 19.99us, <20.00us, 535, 574464, 20304
11, 20.00us to 29.99us, <30.00us, 2, 130055, 8
12, 30.00us to 39.99us, <40.00us, 0, 87345, 125
13, 40.00us to 49.99us, <50.00us, 1, 48237, 980
14, 50.00us to 59.99us, <60.00us, 1, 57121, 35
15, 60.00us to 69.99us, <70.00us, 0, 43291, 2
16, 70.00us to 79.99us, <80.00us, 0, 35595, 4
17, 80.00us to 89.99us, <90.00us, 0, 25973, 0
18, 90.00us to 99.99us, <100.00us, 0, 23418, 0
19, 100.00us to 109.99us, <110.00us, 0, 32152, 0
20, 110.00us to 119.99us, <120.00us, 0, 22362, 0
21, 120.00us to 129.99us, <130.00us, 0, 15856, 0
22, 130.00us to 139.99us, <140.00us, 0, 12421, 0
23, 140.00us to 149.99us, <150.00us, 0, 11721, 0
24, 150.00us to 159.99us, <160.00us, 0, 10490, 0
25, 160.00us to 169.99us, <170.00us, 0, 12437, 0
26, 170.00us to 179.99us, <180.00us, 0, 14880, 0
27, 180.00us to 189.99us, <190.00us, 0, 18776, 0
28, 190.00us to 199.99us, <200.00us, 0, 16737, 0
29, 200.00us to 209.99us, <210.00us, 0, 15229, 0
66, 570.00us to 579.99us, <580.00us, 0, 1, 0
68, 590.00us to 599.99us, <600.00us, 0, 3, 0
71, 620.00us to 629.99us, <630.00us, 0, 1, 0
73, 640.00us to 649.99us, <650.00us, 0, 1, 0
74, 650.00us to 659.99us, <660.00us, 0, 1, 0
81, 720.00us to 729.99us, <730.00us, 0, 1, 0
83, 740.00us to 749.99us, <750.00us, 0, 1, 0
89, 800.00us to 809.99us, <810.00us, 0, 1, 0
90, 810.00us to 819.99us, <820.00us, 0, 1, 0
96, 870.00us to 879.99us, <880.00us, 0, 1, 0
[b]1009, 10.00ms to 19.99ms, <20.00ms, 0, 592, 2
1010, 20.00ms to 29.99ms, <30.00ms, 0, 4, 0[/b]
1108, 1000.00ms and greater, >=1000.0ms, 0, 0, 263
TOTALS, 7279281, 7867531, 272239
