- 5 Aug 2006
- Derbyshire
As title really. I use vista 32 and with my 54mbps netgear usb adaptor and it wouldnt even do the 'beep beep' hardware detected noise. We get a new router as the old one died and it came with a 104mbps (or whatever) netgear adapter and it works fine upon start-up, then decides there is no adaptor plugged in or it says device malfunctioned. So internet use is limited to 5 mins then a restart is needed.
Is it just netgear products doing this??
Anyone got a specific pci/usbwireless adapter they recommend??
The current two adapters are usb ones.
I think its something to do with windows as sometimes it wont even do the beep beep noise
