Wireless adaptor
14 Dec 2004
South
If I have a netgear router, can I use a different make wireless adaptor?
Just my WG111T wont work in vista and need a new one.
Any recommendations of something that will work!?!?!?
Cheers
Yep, you can mix different makes of kit.
I dont use vista so I can't tell you what works well. Just check the manufacturers web site to see if drivers are available for Vista before you buy.
