Wireless ADSL router advice (~£60)
29 Jan 2004
Earth
Hi
I've got a Netgear DG834, but now need a wireless adsl router.
I'm looking to spend around £60 max-ish. - 2 laptops, xbox (wired), and a mobile phone will need to be able to connect to it.
Thanks in advance:)
DG834G is basically the same model with wifi and would do the job. Or are you looking for any specific extra features?
You could also just buy a standalone WAP to add wifi to your existing wired router. Not necessarily any cheaper but might give more flexibility with positioning for best coverage.
I got a Sky branded Netgear DG834GT for about a tenner and flashed it with DGTeam firmware.
Has been perfect - slighty increased sync speed over my old router and very stable.
2 ethernet connections, about 6 laptops, one Wii, one iPhone and one iPod Touch all use it without any issues.
