I have been asked to install wifi around a local farm but also the ability for IP cameras. Its a large farm so in certain sheds I need a poe switch for cameras but some sort of wifi access point.
The problem I need to overcome is the dust, cobwebs and in the winter times you have damp especially when the roof drips or the walls gets wet from condensation.
Has anyone installed such setups in similar conditions and if so what did you use?
I've thought about using outdoor access points in the sheds and because they are large open sided sheds, they should output the wifi throughout the shed and any areas outside that are within range.
The poe switches are a problem as to how to keep them free from the dirt and damp.
Any suggestions would be greatful.
