wireless ap & two gateways?! - visitor access
17 Jan 2006
NW
I've got a DHCP network which has a default gateway.
I also have a Guest ADSL account which has a static IP and no dhcp.
Is there any access points or way round having two SSID'S on the access point, creating a "visitor" ssid and sending them through the second gateway.
or should i just installed two access points all over the office
cheers
Do you have WAPs that support multiple SSIDs? If so, then VLANs are the way to go. The guest network can then run on it's on subnet using the guest ADSL.
