Wireless bridge question
20 Jun 2006
Iv tried searching the net for this question but cant seem to find a answer.
Do you have to connect to the bridge manually once setup or does it just act as a signal booster for the main router?
Example...
One room in a house has zero wifi so has a bridge setup in that room, do you have to connect to that bridge maually or does it kinda piggyback the main router signal....does that make any sense?
Thanks neil
Ok my main router is a belkin n1 vision which has replaced a dlink dir-615.
Was going to use the 615 to get better signal upstairs for the ipads
