Wireless Bridge
4 Oct 2004
Northants
I have a Buffalo WBMR-G54 downstairs that is connected to the internet as a wireless router (nothing is plugged into the ethernet)
Upstairs i have a wired network using a netgear gigabit switch, netgear adsl modem but only using the switch side of it, and a linkysys wireless acces point (WRT54GL).
Is there a way to make the two wireless devices part of the same network so that if somone on the wired network wants the internet it would go "comp-linsys-buffalo-internet"
I used to be able to do this on an old access point that i had because it had a bridge feature, on these newer ones there are so many setting and i think it'll be something to do with routing but not entirely sure how to set the routes so that it'll work.
Thanks in advance.
~Hennerz~
