Wireless cable router question
18 Oct 2002
Surrey
Hi,
Looking for a way for my friend to access internet on her laptop wirelessly and to be able to connect a desktop and xbox 360 for internet use via ethernet.Would the d-link Here do the trick? Thanks in advance.
Yes, but does She actually need all that throughput? Wireless cable router can be had far cheaper if it is a) small range and b) lower bandwidth needed.
WRT54GL + Tomato firmware
£40
This.
Unless shes going to be streaming Hi Def content through her network then she doesnt need an N router.
A Linksys with Tomato is probably the most reliable and effecient piece of kit you could get.
