Wireless - cant acquire IP address or see default gateway
20 Oct 2002
London
I recently moved into a new house where they have Virgin wireless set up. I have a PC but due to space am borrowing a laptop for now. Although i can see the wireless network fine and even connect to it, when it connects it says it only has ''limited connectivity''.
Basically it is struggling to find the default gateway, and as such doesnt acquire an IP address.
Here's what ipconfig says. You can see what the settings should be by looking at the ethernet/wired settings.
C:\Documents and Settings\Dave>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : MOBILEDAVE002
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Intel(R) PRO/100 VE Network
Connecti
on
Physical Address. . . . . . . . . : 08-00-46-E5-0D-EA
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 192.168.0.100
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DNS Servers . . . . . . . . . . . : 194.168.4.100
192.168.0.1
Primary WINS Server . . . . . . . : 10.99.4.2
Lease Obtained. . . . . . . . . . : 02 June 2008 23:22:31
Lease Expires . . . . . . . . . . : 09 June 2008 23:22:31
Ethernet adapter Wireless Network Connection:
Description . . . . . . . . . . . : Intel(R) PRO/Wireless 2200BG
Network
Connection
Physical Address. . . . . . . . . : 00-0E-35-22-19-5B
Autoconfiguration IP Address. . . : 169.254.78.227
Subnet Mask . . . . . . . . . . . : 255.255.0.0
From the looks of it, it's a D-link wireless router plugged into the Virgin box.
Any ideas? I've tried changing settings numerous times, doing the wizard, doing a million repairs on the connection etc... :confused:
Thanks.
Positive. I took it off my housemates settings, and you can see it there^ when i plug in with wires.
can anyone else connect wirelessly mate?
have you been on the router config page to see if every looks ok?
Whenever I have seen this its because the security settings for wireless arn't right.. it says its connected but its not really.
Review all the settings and the key that you are using :)
Argh. It was the password. My housemate had written it down wrong. Honestly.. why couldnt it just tell me the password is wrong?!? :mad:
