Wireless capability problem
23 Mar 2010
hi
so theres the problem.
everytime i startup my laptop, it wont connect to the internet (or you could say the router). i have enabled wireless (the LED light is 'ON' on the laptop) and the router works just fine.
its just everytime have to 'diagnose and repair', then click on 'turn on wireless capability' for me to connect to the internet (which is annoying). :(
it used to connect automatically to the internet everytime i started up. but now it doesnt.
is there a solution to solve this probleim guessing its the wireless adaptor problem.
by the way its a Amilo Li 1818 laptop if it helps
thanks
