Wireless Connection before login,
17 Jul 2008
is there a way to make the wireless connect on vista before the user logs in, or at least before all users\startup items start to run?
I have an issue where a user logs in but the drive mappings keep failing because they try and connect before the wireless connects.. -
thanks for any advice,
Had the same very issue as you. If your mappings are done by a bat file then add a ping to the command and then let it map the drive.
If youve done it by the mapping wizzard then there isnt much you can do.
