- 28 Mar 2005
- Reading
Hello, I'm trying to set up my parent's laptop to access the internet from the other side of the house to the router. The belkin 54G router is connected to NTL, and the main pc connects to the router via ethernet cable. All works fine. The laptop used to connect wirelessly without a problem from where it was situated (about 10-15 metres from the router) up until a few weeks ago.
Anyway, I had a connection last night. Then I tried to activate the security settings and messed something up. I can connect the laptop wirelessly to the existing network (unsecured) when I'm in the same room or not so far away from the router. Back in the old room, however, it only picks up a secured network connection (which is the one I made secure) and not the unsecured one. It asks for a192 key, which I enter - then it just says acquiring network address for ages, and then finally "limited or no connectivity" despite saying it is connected to the network (I think it is acquiring a private ip address, and won't repair either). It doesn't seem to be really connected either, because I cannot do anything when it is connected to the secured network - regardless of whether the laptop is near the router or not.
In one way, it seems like a simple case of signal strength but that doesn't really explain why it worked fine before. Any ideas about how to correct this issue?
Thanks
Bornslippy
Thanks
Bornslippy
