- 23 Oct 2002
- N Ireland
A friend is running a laptop with a clean install of XP Pro.
It has an Intel built-in wireless adapter.
The router is a Linksys WAF54GS and one other PC is connected to it by way of Netgear XE102 ethernet bridges. This PC can connect no problem.
The laptop can connect initially but the connection keeps dropping after about 20 mins. The network is unsecured and all of the configuration settings in the router are correct.
I have exchanged the router once and the problem still occurs. The laptop is in the same room as the router.
sorry for the longwinded post but I am at my wits end
any help would be great
Thanks
Brian
Thanks
Brian
