Wireless Connection Repair Wizard
Permabanned
21 Apr 2004
Southampton University
Is there a way to do just the last steps of this, re: the DNS and whatever else it does?
As usually when it work, it will fix my connection problems, but more often than not, it's useless and can't reconnect. Yet as soon as I hit cancel/close and the wizard goes away, it instantly reconnects, however not fixed.
So i'm guessing what fixes it for me is the few steps at the end after it reconnects which it isn't getting to do, how can I do them myself?
Use a command prompt and IPCONFIG /flushdns or whatever command you think you need. IPCONFIG /? will give you options.
