Wireless Connection to Windows SBS 2011
9 Aug 2011
I'm building a network for a friend but he wants the computers to connect to the server wirelessly.
At present, the setup is:
Broadband Modem > Firewall > SBS 2011 Server > PC's (all connected via switch (except the BB Modem).
To enable the computers to connect wirelessly, what's the best way to do it? Should I get a wireless firewall or just get a wireless access point to sit between the pc's and the current firewall?
Thanks
i'd get a wireless access point and connect it to the switch which will then give you the firewall protecting the internal network. Make sure you set up the security on the wireless with a decent encryption key.
Thanks - will the pc's be able to log into the network domain via wifi? Thanks again
