 - 8 Feb 2008
 - UK
Hey =D
I have recently experienced a problem with my wireless connectivity and wondered if anyone could shed any light on it.
Basically I have a laptop for work which has a integrated wireless card, I think its the Intel PRO/Wireless 2200BG from memory. It operates probably 2/3 metres from the router and everything has been working fine for months. However, recently I have been unable to send/receive files across my network from/to that laptop. When sending files the estimated time will shoot up to 100's of minutes and will more often than not fail. It is the same when accessing the internet, downloading a file will cycle between moderate speeds to nothing at all. The network icon tells me that the signal is excellent, which is should be! but the connection speed will rise from 54 and down to 24mbps in a sort of cyclic pattern [rising and falling]??? To check that is not the router I have used other wireless computers [even 3 floors down] which experience no problems.
Obviously its integrated so if something is wrong with it i guess a new adapter is required?
Any help is kindly appreciated.
