Got virging media broadband so currently running the superhub which is located upstairs.
Our living room downstairs is a deadspot, signal strength is practically non existent most of the time and only occasionally kicks in. I'm not sure its a problem with the hub more the construction of the house....its like we have lead walls as we get zero mobile coverage as well.
So looking for a reasonably cost effective way of getting wireless into the living room.
Any suggestions on a decent range extender, ideally one that will work with the superhub in router mode.
If I can avoid doing so I wont get a router and change the hub to modem only i've not really had any problems with the hub so if i can avoid the added cost i will!
ty
ty
