Ok time to explain.
I have potentially 200MB fibrenet connection at home.
If I hardwire cat 5e cable to my laptop I can get a constant 95Mb to my laptop (hardware is obviously 10/100 and not gigabyte.)
However my iphone 4s is capped at around 45MB ?
I presume this is due to it running on wireless G? But can't find much info on that.
If I stand next to the router with my ipad retina I get 75Mb but not more if I move 2 meters away this drops to 50Mb and my couch 3 meters away is 45Mb.
I'm on channel 8 my neighbours are on channels 11 and 1 and my cable companies wifi router is on 2 but I don't use it since I can't manage it directly. No one else seems to be using the 5GHZ range but I find that that is even weaker than the 2.4 range.
My walls in my house are made with red concrete blocks (14cm thick) these seem to obliterate any wi-fi reaching the rest of my house even in my bedroom which is only separated from the router by 2 walls and around 5 meters I don't get a signal at all. I tried buying a range extender but find for it to work at all I have to plug it in the same room as the router.
People have talked about getting 65 foot range on these extenders I struggle to get decent range within 10 feet of the extender.
Apart from ripping my house apart to cable the whole place is there anything I can do to increase the range (even if it means a better router?) or 2nd Access point.
I am using home-plugs at the moment but I'm lucky if I get 10Mb through them so not really benefiting from my fibre net, but at least I get a signal in my bedroom
Any ideas or help.
Cheers,
John
I presume this is due to it running on wireless G? But can't find much info on that.If I stand next to the router with my ipad retina I get 75Mb but not more if I move 2 meters away this drops to 50Mb and my couch 3 meters away is 45Mb.
Any ideas or help.
Cheers,
John
