Wireless DSL connection regarding two nearby offices
21 Jul 2005
Officially least sunny location -Ronskistats
For a small office setup where two rented spaces are seperated by a few feet and a wall would it be best to have a seperate connection for each location or try to have one share wirelessly a single connection?
As the signal might not be very strong in the other building, would using an access point or maybe a repeater type box be feasable?
TIA
Th0nt
broadband (based on if you have adsl) going into a DG834 router. Plug in a WG602v3 access point, place another access point in the other office. try to place the 2 access points approx 15metres from each other (based on the fact you have a few feet gap between and 2 walls to go through?
set the access points in multipoint or point to point mode with wireless client association on each.
