Is there such a thing as decent wireless earbuds that have a long battery life?
Good ANC with min 10hrs without charging...
From a google I found this website.
8 Best Wireless Earbuds With Long Battery Life [2024]
Looking for wireless earbuds that can last an entire day or more without charging? We’ve got you covered.www.headphonesty.com
But the only one on that list i have heard of is the Sony WF-1000XM5.
I think your requirement of Good ANC and 10+ hours on a single charge might not be possible.
What do you intend using them for? I listen to audio books all day long and have a very good set of Soundcore by Anker ear buds (with over ear sports support) that I wear 6-10hrs a day, I also have a set of Skull Candy Push Active that are better for music, they have a stay aware mode where it used the microphone to feed you audio from around you, handy when running/cycling.
Depends on your use case and what you believe to be good quality audio.
Depending on how much you want to spend, at the lower price end the Anker Soundcore are decent enough, I don't have a pair myself, but I bought my daughter some for her schoool bus journey, she loves them. Often forgets to put them back in the case and they still seem to work for hours.
No, the XM4s are regarded the best overall by many even with the newer XM5, never had a "white Noise", I would go for the XM4s, the XM5s was barely any update apart from a smaller form factor.I looked at those. Some different models?
I also looked at the over the head Sony Mx5. £299. I tried the Mx4 but noticed white noise. Is that normal?
I'm happy enough with my Jabra Elite 3 Active earbuds, but I don't know how the earbuds actually last between charges as they've to run out on me. Nice sound with at a reasonable price too.
Well I've owned my Xm4s since they where available and still use them everytime in the gym and never got white noise from them.I have heard 'white noise' with them when i have tried a couple in the past...
