Hi there
We have a building with 4 floors and very thick walls, plus a lift shaft in the middle.
For AP i use a Asus Black Diamond ADSL 2/2+ Gigabit WiFi Router 11n Dual Band 600Mbps located on the ground floor. I need to extend the wireless signal to the rest of the building. I was thinking of buying 4 of this
http://www.overclockers.co.uk/showproduct.php?prodid=NW-030-TP&tool=3
AP ground floor
TP Booster 1st floor
TP Booster 2nd floor
TP Booster 3rd floor
The booster on 3rd floor will be able to pull the internet from tp 2nd floor, and the Tp 2st floor from tp 1st floor and tp1st from AP?
If this doesn't work what do you recommend ?
AP ground floor
