**WIRELESS EXTENDERS**
Gangster
OcUK Staff
16 Mar 2008
OcUK HQ
Hi,
So we have a big range of range extenders,repeaters and access points for your wireless signal to allow you to get that strong signal no matter where you are in the house. The extenders boost that signal through your house getting past those thick walls which are causing you poor signal.
ASUS have just released the RP-AC68U AC1900 which is a very nice little repeater for you network.
If powerline is not for you then this is one of the easiest ways to boost that wireless signal throughout your home or office.
Have a look below at a few of the selected products from our vast range and hopefully you will find something that suits.
ASUS RP-AC68U Wireless AC1900 Repeater (90IG01U0-BU9010) @ £139.99 inc VAT
RP-AC68U is an AC1900-class dual-band repeater, with a 3-transmit, 4- receive (3x4) internal antenna array that delivers Wi-Fi speeds up to 1300 Mbps on the 5GHz frequency band and up to 600 Mbps on the 2.4GHz band, for a combined total of up to 1900 Mbps. It’s easy to install with its one-touch WPS button, and it features a high-speed USB 3.0 port that works with AiCloud to give you fast wireless access to files stored on a connected USB storage device. Five gigabit ports let you convert any wired network device, such as a game console or smart TV, to work wirelessly. Smart status LEDs give you all the information you need to know, at a glance.
Features:
- Extend your existing 802.11ac dual-band Wi-Fi network with speeds up to 1900 Mbps.
- Quick and secure setup with just a press of the WPS button.
- Smart LED signal indicator helps you find the best location for optimum Wi-Fi performance.
- USB 3.0 port for AiCloud support and fast NAS performance.
- 5 Gigabit Ethernet ports to convert any wired network devices to wireless operation.
- ASUS ExpressWay uses full-speed device connections to boost performance.
- Roaming Assist helps you to get a stable connection everywhere in the home or office.
Faster Wi-Fi that goes further!
The RP-AC68U wireless repeater has powerful internal MIMO antennas that help to eliminate signal dead zones and improve the coverage of any existing wireless router. It works as a repeater, which means it can extend wireless networking to every corner of the home — even to those difficult, hard-to-reach spots. With blindingly-fast 802.11ac speeds up to 1900 Mbps, it’s ideal for extending your existing 802.11ac Wi-Fi network. This ensures reliable high-speed internet coverage everywhere for devices such as notebooks, tablets, smartphones, game consoles and smart TVs.
Experience ultra-fast wireless speeds
Powered by the latest 802.11ac technology, RP-AC68U delivers ultra-fast wireless-AC speeds up to 1300 Mbps on the 5GHz band and 600 Mbps on the 2.4GHz band — that’s a combined total of 1900 Mbps! This high-performance wireless lets you enjoy ultra-smooth online gaming, snappier web surfing and other bandwidth-hungry tasks without a wired connection.
One-press setup and worry-free connectivity
RP-AC68U wireless repeater installation doesn’t require a CD or even a mouse and keyboard. Simply press the WPS buttons on RP-AC68U and your router, and setup is complete. Optimized performance is assured for a seamless and smooth internet experience. For advanced settings, you can connect RP-AC68U to a PC via an Ethernet cable and access the web-based configuration menu directly, with no disc or app needed. You can even set it up wirelessly from a tablet or smartphone.
Upgrade your wireless network to the ultra-fast 5GHz speeds.
RP-AC68U can add a fast and stable 5GHz network to a single band 2.4GHz router, upgrading it to 1300 Mbps speeds for ultra-smooth online gaming, 4K UHD video streaming and speedier downloading. For an existing 5GHz network, RP-AC68U adds an extra 5GHz network so you can connect even more devices for even greater wireless multitasking.
Specification:
- Network Standard: IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Product Segment: AC1900 ultimate AC performance : 600+1300 Mbps
- Coverage: Large homes
- Data Rate:
- 802.11a : 6,9,12,18,24,36,48,54 Mbps
- 802.11b : 1, 2, 5.5, 11 Mbps
- 802.11g : 6,9,12,18,24,36,48,54 Mbps
- 802.11n : up to 600 Mbps
- 802.11ac : up to 1300 Mbps
- Antenna: Internal antenna x 4
- Operating Frequency: 2.4 GHz / 5 GHz
- Encryption: WPA2-PSK, WPA-PSK, WPA-Enterprise , WPA2-Enterprise , WPS support
- Ports: RJ45 for Gigabits BaseT for LAN x 5
- Dimensions: 178 x 106 x 106 ~ mm (LxWxH)
- Operation mode:
- Range extender mode
- Access point mode
- Media bridge mode
Only £139.99 inc VAT.
ORDER NOW
Asus RP-N53 Dual-Band Wireless N600 Range Extender 300Mbps (RP-N53) @ £62.99 inc VAT
- Dual-band concurrent range extender
- Streaming music with ASUS AiPlayer app or AirPlay
- One-press setup and worry-free connectivity
- Full coverage with internal MIMO antennas
Lights up your Wi-Fi everywhere
The RP-N53 ensures full coverage and no more signal dead zones with internal MIMO antennas. Its strong repeater functionality expands wireless home networking to every corner. Even the hardest to reach spots get high speed internet coverage for notebooks, tablets, smartphones, game consoles, and smart TVs. With superior reception, you enjoy lag-free gaming and HD multimedia streaming everywhere.
We recommend placing the RP-N53 between the router and the area where you want to extend wireless coverage. The RP-N53 works best when it is receiving a strong wireless signal from the router, and you can check this using the signal strength indicator on the front panel of the RP-N53. This shows the signal strength for both frequency bands — the longer the illuminated band, the stronger the signal. Position the RP-N53 so that it is as far away from the router as possible but still showing a strong signal level.
The RP-N53 gets you true dual-band networking even if you’re on an older single-band router. Double your wireless performance with up to 300Mbps bandwidth in 2.4GHz and 5GHz simultaneously! 2.4GHz handles daily tasks like web browsing and social networking, while 5GHz is great for HD video streaming and online gaming.
Enjoy all your favorite music with wireless convenience using the RP-N53 and ASUS AiPlayer. Great compatibility with a complete range of multimedia formats means streaming is smooth and effortless, working every time to bring you plug n play enjoyment, to be shared with those that matter. You can also stream the music with AirPlay of Mac and iOS devices to RP-N53.
RP-N53 installation doesn’t require a CD or even mouse and keyboard. One press of the WPS button and setup is complete. Optimized performance is assured, so internet experiences are seamless and smooth. For detailed management, you can simply connect the RP-N53 to a PC via Ethernet cable and go to the configuration page directly, or quickly set it up from tablet or smartphone wirelessly, with no disc or app needed.
Internet radio
Get your favorite stations via the internet with live streaming, or webcasting. Streams playable through the router's graphical user interface and dedicated app.
Hands-on control for music and lighting
Simply touch a sensor on the RP-N53 to start or stop music playback and turn the LED lighting on and off. All it takes is one touch, adding instant convenience to artistic beauty - plus you can personalize sensor settings via the user-friendly interface
Stylish power lights up your home
The RP-N53 has an additional LED on the back, serving as a gentle nightlight for a very pleasing visual effect.
Flexible and space saving placement options
The RP-N53 uses a back power plug design to help you save space and give you more freedom when choosing device location. It can connect directly to wall sockets or power strips, promoting neater and less cluttered homes.
Only £62.99 inc VAT.
ORDER NOW
D-link DAP-1520 Wireless AC750 Dual-Band Range Extender (DAP-1520/B) @ £29.99 inc VAT
The DAP-1520 Wireless AC750 Dual-Band Range Extender is a portable plug-in wireless repeater that lets you extend an existing wireless network. You can place it anywhere in your home to increase the range of your wireless network. Tiny yet powerful, it supports Wireless AC speeds of up to 750 Mbps, yet fits in the palm of your hand.
Extend Your Wireless Network
Increase the coverage of your home Wireless network with the sleek and easy-to-use DAP-1520 Wireless AC750 Dual-Band Range Extender. Dual-band technology helps reduce interference from nearby wireless transmitters in the home, and also provides backward compatibility with older wireless devices in your network, allowing you to enjoy a blazing-fast, reliable wireless connection.
Easy to Set Up, Easy to Use
Setting up the Wireless AC750 Dual-Band Range Extender is simple. You can use the supported QRS Mobile app on your iOS or Android mobile device to set up the DAP-1520 easily without needing a computer.
Alternatively, you can use one-touch configuration by pushing the WPS push-button on the DAP-1520 and on the router or AP you want to extend, and the DAP-1520 will automatically configure itself for you. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
Compact, Convenient Design
The DAP-1520 is a compact device that is ideal for use at home or in a small office, as it does not take up much space and is ready to use by simply plugging it in. Its diminutive wall-plug design easily plugs into a power outlet without blocking other outlets and saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance blends easily into the decor of your home or office.
Specification:
- Device Interfaces: 802.11ac/n/g/b/a wireless LAN, WPS button, Reset button
- Standards: IEEE 802.11ac (draft), IEEE 802.11n, IEEE 802.11g, IEEE 802.11b, IEEE 802.11a
- Antennas: Two internal antennas
- Wireless Security: Wi-Fi Protected Access (WPA/WPA2), WEP 64/128-bit encryption, WPS (PBC)
- Advanced Features: D-Link One-Touch Extender Setup
- Device Management: Supports QRS Mobile app for iPhone, iPad, iPod Touch, and Android mobile devices
- Dimensions: 92 x 58 x 34.2 mm (3.62 x 2.28 x 1.35 inches)
- Weight: 104 grams (3.67 ounces)
Only £29.99 inc VAT.
ORDER NOW
TP-Link 300Mbps WiFi Range Extender with AC Passthrough (TL-WA860RE) @ £29.95 inc VAT
Features:
Range Extender mode boosts wireless signal to previously unreachable or hard-to-wire areas flawlessly
Miniature size and wall-mounted design make it easy to deploy and move flexibly
Extra power socket making sure that no power outlet is going to waste
2 fixed external antennas provide excellent WiFi coverage and reliability
Easily expand wireless coverage at a push of Range Extender button
What This Product Does
TP-LINK's TL-WA860RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate “dead zones”. With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier. In addition, its extra outlet makes power available for other electrical devices. What's more, its Ethernet port allows the TL-WA860RE to act as a wireless adapter to turn a wired device into a wireless one.
300Mbps Range Extender
The TL-WA860RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate “dead zones”, help users maintain an existing wireless network and vastly improve the network’s coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
Flexible Deployment
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA860RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
Extra Power Socket for Additional Devices
With its integrated power socket, the new TL-WA860RE provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the Range Extender as though it were a normal wall socket. This ensures that even with the TL-WA860RE plugged in, no power outlet is going to waste.
Plug and Play
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA860RE or vice versa.
<b>Superior Range</b>
<p>With 2 fixed external antennas combined with higher quality antenna technology, you can experience excellent WiFi coverage and reliability no matter where you connect in your home.</p>
Ethernet Bridge
The TL-WA860RE's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
Smart Signal Indicator Light
Intelligent signal light can help to find the best location to place the range extender so that the TL-WA860RE can achieve the best possible range and performance of the network.
Universal Compatibility
It works seamlessly with all 802.11 b/g/n wireless devices.
Only £29.95 inc VAT.
ORDER NOW
TP-Link 300Mbps Universal WiFi Range Extender (TL-WA854RE) @ £14.99 inc VAT
Highlights:
TP-LINK's TL-WA854RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate “dead zones”. With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier.
The TL-WA854RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate “dead zones”, help users maintain an existing wireless network and vastly improve the network’s coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
Flexible Deployment
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA854RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
Plug and Play
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA854RE or vice versa. An additional push of the pair button can quickly establish an encrypted connection with client devices.
5 signal lights represent the current signal strength that TL-WA854RE receives from existing router, which can help to find the right location to place the range extender so that the TL-WA854RE can achieve the best possible range and performance of the network.
Works seamlessly with all 802.11 n/g/b wireless devices. It is also compatible with the latest Windows 8 operating system.
Only £14.99 inc VAT.
ORDER NOW
View our entire wireless extender, repeater and access point range here
