Wireless FAQ sticky?
Permabanned
2 Oct 2008
Is it still relevant considering it was posted in 2004?
Apologies for starting a new thread but the last post was 18 months ago so fear my question will get lost in it!
I've just bought a new laptop which has wireless connectivitiy on it and was wondering that if I bought this would I just connect it to my current router in a daisychain (is that right?) and be able to connect the laptop wirelessly?
I really am a noob :eek:
That would replace your cable router altogether, if you're on cable.
For a little more cash, you could get a WRT54GL, which is a much better router. Alternatively, you could add a wireless access point (or another router) to the router you have.
Thanks for that, I should probably add that I have two PC's and my xbox360 currently using my router and they aren't wireless. Is the new wireless router that I should buy pretty much the same as I already have but witht he added bonus of the thing sticking out of the top (tech term!) which will connect to my wireless laptop?
I reckon it's probably best that I go into a shop and have a look at a physical specimen!
It doesn't have to have antennae to be wireless; it'll have a wireless card inside and probably a different firmware version but yeah, fundamentally they're the same.
That's the sausage.
Why is the one that you've pointed out better than the cheapo one that I found? Whats the difference and am I likely to notice it?
It does a whole load of features like QoS, and you can install non-Linksys firmware that'll add yet more features, as well as improving the range. It'll probably be more stable too.
Well I'm quite happy to use the benefit of your experience and buy that one then.
When I get it will it be a simple case of plugging everything from the existing LAN into the new one, rebooting the cable modem and plugging in?
I've had real connectivity issues lately and it's horrible when the internet doesn't work!
Yes, you should just be able to switch them about. The longest part will be getting the cable modem to play ball (but that's hardly difficult).
