thankx man sounds good. Is it worth going for 5.1 headsets instead of stereo?
I wouldn't say so. I tried the Speedlink Medusas Home Edition 5.1 headphones, and I thought they were absolute junk.
They weren't made very well: it felt like they were going to break when handling them since the joints between the cups and headband felt so weak.
Gaming wasn't
too bad, I suppose. I mean, sound positioning worked to a certain extent, in that I could hear roughly where sounds were coming from (whether it was from behind or in front, left, right, etc.). However, since the drivers inside each cup are so small, they sound very tinny. This is especially emphasised when trying to hear sounds coming from the behind, a problem many seem to have with these particular 'phones, because the "subwoofer" speakers inside of them don't work in conjunction with the rear speakers. Therefore, bass could only be heard when sound was coming from the front of me, so when sound was coming from behind (whether it be a rocket launcher or the apocalypse), it always sounded like something flicking a tin can with their finger. Even when the "subwoofer" speakers were working, I couldn't get these 'phones to produce any low frequencies for the life of me. In Oblivion, for example, swinging a sword usually produces a warm "swumph" sound--not the best onomatopoeia, but eh--which sounds absolutely terrible with the Medusas. Same with CS:S; guns sounded like those little wooden guns that shoot corks attached to a piece of string you had when you were a kid, but worse. I guess, what I'm saying is, I didn't have the
best experience with these headphones when gaming, which was their intended purpose when I bought them.
I have a similar opinion on their music performance, too: It was pretty crap. Without using CMSS-3D, or something similar, only the front speaker in each cup would output sound so, as you can imagine, the quality wasn't too overwhelming. Since there are 4 drivers in each cup, they have to be shrunk-down in size in order for them to fit, obviously compromising their output capabilities. Basically, it wasn't very good for me, since only 1/4 of the 'phones potential was being used, and even then it wasn't being used very well.
Sorry for the long read, but I just thought I'd voice--well, type--my opinion so someone doesn't make the same mistake I did. Now, you might be thinking: here's someone who's picky about audio, and the Medusas will probably be fine for
me. Well, let me tell you, I am by no means an audiophile. In fact, I consider myself quite the opposite. Against the advice of others to get stereo headphones, I regretfully got the 5.1 ones which I thought I'd be totally happy with, after all, I've been using 5.1 PC speaker system which cost me £20 from an auction site. Anyway, the point is, I'm not picky at all and the Medusas sounded terrible, even to me. I'd skip out this stage, and go straight to getting some stereo 'phones which, by the way, I've found to be better at positional audio than the 5.1 Medusas I used previously.
