Wireless gaming(ish) keyboard and mouse for under £50??
7 Dec 2008
UK
Well my curent set (Microsoft wireless laser desktop 3000) isnt the best, i cant use more than three keys at a time (not useful in a fps when your running diagonally while sprinting trying to reload and trying to crouch) and if your holding 2 buttons and let go of one it stops registering the second button aswell. and then theres the mouse where, as always seems to happen with my mice the wheel has stopped acting as a button but only the wheel, which is a huge pain in the ass
so, a new set (or advise on fixing my current problems would be preferable) i dont plan to buy a mamba and a G19 for over £200 as they will probably end up in the same condition (i got the current set for christmas) is it possible to get a wireless set (with good signal and range) that can handle games? something sturdy and resiliant preferably
I think you're wanting too much at a low cost tbh, but best bet would be something like this, little over at 65, but you get what you pay for, why not just stick with wired anyway? best for gaming
have to have wireles with my current setup which is a shame but cant be helped, i can go over budget if possible but i want the lowest price i can get get away without it h9indering what ill get
