Wireless gaming keyboard
8 Jan 2012
Hi all.
I need to get a wireless keyboard as I'm dispensing with a desk in favour of gaming from a recliner.
The keyboard needs to be full size as the width fits better on my legs and preferably not too heavy if I decide to hold it while typing - it will not be used for WASD gaming - I have a Tartarus Pro for that, it's just for typing.
Also it needs to be quiet - I hate clicky keys - Optical preferably but linear are fine too and a UK layout. The keycaps need to be replaceable too and it must have RGB lighting.
I've looked at the Asus Claymore 2 and it ticks all the boxes but it's just so expensive while the Razer Blackwidow V3 Pro only comes in green clicky switches in the UK layout.
The Logitech G915 I've heard doesn't have replaceable keycaps (I may be wrong)
Can anyone suggest any other alternatives?
Thank you.
Logitech G915 fits your needs perfectly apart from the keycaps, which as you say are not replaceable.
Maybe check out Keychron's offerings? Specifically the Keychron K4 ISO.
