- 10 Apr 2004
In a shared flat, with a WRT54GL acting as main router for 20MB VM service.
I have a Airport Extreme set at 5GHz N for my MacBook Pro, but the 5GHZ penetration is worse than the 2.4Ghz.
Now the WRT54GL is under the TV next to the modem and IP-connected TV, but my mates are on the other side of the flat (so it's all on the same floor). Don't need 360 degrees coverage, and even 180 degrees would be too much really.
They barely get 30% strength and don't get the full 20MB.
Now, I've upped the wireless output power to 105mw and over clocked it to 216mhz (running cool, so that is fine.)
Currently channel 3, with a few week (<20%) AP dotted around channels 1, 6 and 11. Changing from channel 8 to channel 3 gained 5-6%.
But we need more, after a few hours googling I don't really have an answer to this:
What antenna setup would work the best?
Currently have the two of the original 2-3DBI antennas.
Would two 5/7/9/11/etc DBI antennas improve things? Would the reduction in vertical coverage matter on a single floor flat?
Do I need two antennas or would one be best?
So I suppose the general question is: What antenna setup should I have to increase the strength to my mates rooms?
Cheers!
Cheers!
