So I have a wired network on a decent router already set up at home but it doesn't support wireless, rather not change it.
Would adding a wireless access point to this work with the wii, just that every article I've read seems to have mentioned using a router or the DS dongle.
Anyways, if this'll work will someone kindly point me to an access point is known to be compatible (or would my wired router be the bigger part of the equation?).
If not I guess I'll have to swap out (in which case please point me to router(s) that are known to work
or buy a long cable, usb ethernet adaptor and shove that in.
As the wireless access point would be used wii exclusively I'd rather it was as cheap as possible, but if I must get a wireless router I'd prefer it to be a good spec and have at least 4 wired ports.
Damn nintendo for making it harder than it needed to be.
or buy a long cable, usb ethernet adaptor and shove that in.As the wireless access point would be used wii exclusively I'd rather it was as cheap as possible, but if I must get a wireless router I'd prefer it to be a good spec and have at least 4 wired ports.
